I have a simple lubrication contamination control tip that has been lost due to lack of training in our "Getter done!" world.
It's common sense really, wipe grease nipples off before and after you grease them.
Obviously, before to ensure you do not inject contamination into the process, and after to reduce the contamination that will accumulate on the grease nipple the the next yahoo that doesn't wipe it off can inject into the process, or is easier for him to wipe off.
I love your articles, please, keep up the good work.
Reader tip provided by James Morgan
Manufacturing Engineering
Formet Industries Ltd
St. Thomas, Ontario
Canada
Thanks James - glad you like the articles too! Your diamond plate stainless steel coffee mug is on the way.
Click here to send in your own maintenance tips and get a Maintenance Tip hat or Stainless Steel Diamond Plate Reliabilityweb.com travel coffee mug if we publish it.
Link click here to: http://reliabilityweb.formbin.com/forms/tips
ChatGPT with
ReliabilityWeb:
Find Your Answers Fast
Start
