Level Up Your Reliability Skills: Get Certified! Boost your career now!
Elevate your industry profile at The RELIABILITY Conference.
Organizing a Successful PdM Program
Predictive maintenance is a systematic method of monitoring and trending rotating equipment on a regularly scheduled basis to determine the condition of machines subject to wear and tear. On-line detection, trending, and diagnostics methods provide an early warning of potential problems and virtually eliminate the need for periodic disassembly and inspection, and the possibility of an unexpected breakdown.
There are twelve essential steps in building a Predictive Maintenance Program. The flow diagram is available by using the link below.
1. Plant survey
2. Machine selection
3. Select optimum condition monitoring techniques
4. Establish predictive maintenance system
5. Set and review acceptable condition data and limits
6. Machine baseline measurements
7. Condition measurement
8. Data collection
9. Data recording
10. Trend analysis of faults detection
11. Condition analysis
12. Fault Correction
Tip Provided by Commtest Inc.
http://www.commtest.com
