by Terry Wireman, Author
If one considers asset management as caring for the assets of an organization, then it is true that Work Execution Management enables asset management. If one considers that reliability engineering for maintenance and asset condition management generates the work to be performed, then Work Execution Management is the process in which the work is accomplished.
Join Terry Wireman as he gives an overview of the recently published, Work Execution Management (WEM) Project Manager’s Guide. This guide and webinar is your recipe for success. It reflects best practices common to all major WEM approaches and includes lessons learned from organizations deeply involved with the subject. The future of WEM is about to change!
If you have not downloaded the WEM Project Manager's Guide, download below.
