2-Stage Routine for Finding Air Leaks
A 2-stage approach to leak detection can improve your results. The first tour of the compressed air system will identify large leaks that are easy to fix. Smaller leaks in complex systems are harder to find and are often masked by larger leaks. The second tour should be conducted after the larger leaks are fixed, locating smaller leaks that will one day become more problematic ones.
Get the Leak Surveyor Handbook
SDT Air Leaks
Tip Provided by:
