BorgWarner Increases Overall Equipment Effectiveness with Leading2Lean Cloud-based Lean Mfg
RENO, Nevada
Area employees drive this process optimization—scheduling, planning and monitoring performance of machines on their lines—all through the Leading2Lean product. “It’s as easy to use as Facebook or Google,” said Will Venet, TPM Implementation Leader at BorgWarner.
Experienced managers also find the system intuitive. “What a reliability engineer took decades of experience to learn can be learned in an afternoon,” Venet said.
Plant Maintenance Engineer Rodney Osborne said the crew used to use “gut checks” to guess which machine needed maintenance or how much money they spent on spare parts for a machine.
“But now with Leading2Lean we do a simple report and it tells us—there’s no ambiguity,” Osborne says. “It takes the gut check out of it. It’s real data, and it’s without question a much better way of doing business for us.”
Initially, some employees thought bringing in the Leading2Lean system was an oversight effort, like “Big Brother,” but results soon changed their minds. Today, there is a far more collaborative relationship between Production and Maintenance, and team members at all levels feel more engaged because they are empowered to identify and produce solutions for continuous improvement.
Downtime reductions were driven largely by the engagement of operators. This was because they had easy access to the data and the manipulation of that data to drive improvements in preventative maintenance.
What used to take four or five days to analyze through laborious data mining can now be done in 20 minutes.
“The collaborative efforts the team is making for continuous improvement are influenced by having a tool that is universally appreciated,” Venet said. “I’ve come to appreciate that what Leading2Lean is really doing is helping us to be a better manufacturer all around.”
About Leading2Lean
Founded in 2010, Northern Nevada-based Leading2Lean is focused on solutions for multinational manufacturers. Leading2Lean is focused on operational excellence and run by an executive team with extensive experience in manufacturing, engineering, and turning around failing enterprises. Its cloud-based systems provide critical real-time information to help rank-and-file workers do their jobs better and take ownership of their work. A better-focused and motivated workforce produces more and of better quality, and leads to habits of continuous improvement. For more information, call 877-225-5201 or visit www.leading2lean.com.
