Brushless DC Tachometer/Commutators from ServoTek Products Aid in Industrial Motor Speed Monitoring
The high-accuracy TachSyn may be used as either a brushless DC tachometer or brushless DC motor commutator for monitoring the rotational speed of brushless industrial DC motors. They offer an economical solution to many velocity-loop problems, whether brushless or standard servo. The robust design of the ServoTek Products TachSyn transducer consists of a primary magnetic sensing device, in which output windings, field winding, and a permanent magnet are all co-located within the stator itself, maximizing reliability. The transducers are available in several unique models to commutate 4-, 6-, or 8-pole brushless DC motors. Any sized TachSyn tachometer may be specified in applications where a simple DC tachometer signal is the only requirement. Pancake-shaped TachSyn transducers are easily mounted, cantilever- style, to the back of a motor or other device, with synchro-type adjustment for phasing.
Each TachSyn transducer requires one CT-4 Series circuit board (or a customer-supplied equivalent), as well as a connecting cable with double-barreled shield to complete signal conditioning. The CT-4 circuit board provides AC field excitation for the transducer and conditioning for its output signals, which include a linear low-ripple DC tachometer voltage, and either a Hall-equivalent or sine-wave commutation signal. The circuit board may be housed up to 100 feet from the hot-running motor, leaving only the non-electronic transducer in close proximity. Standard configurations are normally in stock, and may be ordered online via the company’s website.
For more information about ServoTek Products and its available offerings, contact the company at 1-800-727-5646, via email at customerRFQ@marshbellofram.com or visit www.servotek.com.
About ServoTek Products, Inc.
A member of the Bellofram Group of Companies since 2011, ServoTek Products, Inc., is a world renowned manufacturer of instrument-grade DC tachometers and low-cost encoders, serving OEM customers involved in aerospace, automotive, industrial machinery control, robotics, lift and process monitoring related applications. ServoTek products are known for their rugged designs, high-reliability performance in challenging environments, and proven pedigree across thousands of successful field installations.
