Budget-Friendly UV LED Flashlight Ideal for Industrial Leak Detection
Westbury, New York
Poorly maintained equipment can leak more than fluids, it can leak money. Spectroline’s LeakTracker™ ( LT-300) is a powerful, economical leak detection flashlight that’s ideal for all industrial fluid system applications. LeakTracker has a high-output UV LED that delivers superior fluorescent dye response, making industrial leaks easier to spot. It works with all oil- and water-based fluorescent dyes, including difficult-to-fluoresce yellow, white and blue dyes—even in dirty fluids.
Finding leaks is easy is as simple as:
- Add a small amount of dye to the system
- Let it circulate. The dye/fluid mixture escapes with the host fluid wherever there’s a leak
- Shine the LeakTracker flashlight on all leak sites to observe the brilliant glow
The LeakTracker’s compact size allows it to get into cramped areas larger lamps can’t. It’s rugged, corrosion-resistant body stands up to years of heavy use ( AAA batteries included), the unit features a 100,000-hour LED service life.
LeakTracker comes complete with a lanyard, belt holster and UV-absorbing glasses.
The best thing about Spectroline dyes is because they are formulated to work with their host fluids…they will never degrade the fluid properties or damage any system components. That means there is no need to waste time or money flushing them away. When used with Spectroline dyes, the LeakTracker will quickly become your most cost-effective, proactive maintenance tool for finding future leaks too.
For more information, call toll-free 1-800-274-8888. Outside the U.S. and Canada, call 516-333-4840, or check us out at Spectroline.com.
