Cut out the waiting with the MDM300 Advanced Dew-point Hygrometer
Recent research into the operation of Michell Instruments´ ceramic sensor technology has helped the MDM300 provide faster measurements.
This super-fast response does not rely on the sensor being dried by a desiccant, which means that every measurement is fast - not just the first of the day - allowing for many more measurements to be taken each day.
However, this is not the only way in which the MDM300 cuts out waiting. Efficient nickel metal hydride batteries and power management circuitry provide the user with 48 hours of use between charges - giving much more time in the field making measurements.
In addition a flat battery can be recharged to 90% of its full potential in just 20 minutes, thanks to the intelligent charger.
With its Bluetooth connection, the MDM300 connects wirelessly to a PC. This means no more time lost in locating, untangling and plugging in cables. Set-up of the instrument and downloading of logged data is therefore quick and simple.
A number of cost-effective and easily-portable sampling systems are available for the MDM300 to ensure accurate measurements and help prolong the life of the sensor. These range from simple fixed orifices for low pressure measurement all the way to high-quality configurable sampling systems for pressures up to 400 BarG, designed for use in natural gas and other demanding process environments.
To maximize flexibility, measurements can be taken by means of external sensors which are easily connected to the MDM300. These sensors can be used display dew point, pressure or temperature or can be used to provide pressure and temperature compensation to the displayed moisture parameters.
More information at http://www.michell-instruments.com
