Diversified Machine Systems Partner Announces an Interactive Editor for Easy G-Code Programming
Fagor Automation, a strategic partner of Diversified Machine Systems (DMS), a designer and manufacturer of CNC routers, makes machine programming even easier with their on-floor programming Interactive Editor tool.
Offered as an additional feature to the Fagor 8055 CNC Control, routinely used on DMS CNC Routers, the Interactive Editor enhances the simplicity of programming by allowing the programmer user to choose the type of operation function, followed by assisting the programmer through the entry of all necessary variables to follow. The Interaction Editor is easily accessible through the ‘Edit’ mode on the controller by selecting the Interactive softkey.
All cycles within the Interactive Editor are available when entering the appropriate variables per the instructions and Graphic Assist screen. Once completed, the user operator presses the Enter key to create the cycle that gets automatically inserted into the G-code part program. The tasks available are for machining canned cycles, probing cycles or contouring choices.
All Fagor Interactive Cycles can be called upon directly from the part program by keying the cycle G-code and pressing the Help key. If the user is unsure about the operation of the G-code, they can enter the letter “G” and Help key to get a list of all the G-codes that can be scrolled through to find the intended operation.
Fagor also offers an on-board mini CAD/CAM system named the Profile Editor that allows for quick and easy creation of simple profiles. When completed, the contour G-code is automatically generated and inserted directly into the part program. An extensive background in G-Code programming is not necessary with the ‘Teach-In’ mode, which allows for simple program creation through successful manual and MDI machining. Program verification is achieved even faster and easier in simulation mode with Advanced HD Solid Graphics that includes part zoom and multi-angle views.
All Fagor CNC Controls include Ethernet capability, RS 232 serial port, and USB Connection which allows for offline modern CAD/CAM program creation. Diversified Machine Systems partnered with Fagor Automation to be their exclusive supplier of control systems, now offered standard on all DMS CNC routers, because of the superiority of their product and their similar approach to business. Like DMS, Fagor is committed to improving the customer experience through continual product advancements and ongoing innovation.
Learn more about Diversified Machine Systems at http://www.DMSCNCRouters.com.
ABOUT DIVERSIFIED MACHINE SYSTEMS & FAGOR AUTOMATION
Fagor Automation is a worldwide Manufacturer of CNC Systems, Servo Motors & Drives, Feedback Systems, DRO Systems & Motion Control Systems and strategic partner with Diversified Machine Systems.
Diversified Machine Systems (DMS) is a leading designer and manufacturer of 3 Axis CNC Routers, 5 Axis CNC Machine Centers, and Large Format Machine Centers headquartered in Colorado Springs, CO. With more than 30 years of innovation and industry experience as an Original Equipment Manufacturer (OEM), DMS’ line of CNC routers and machining centers are routinely used on materials such as wood, composites, aluminum, steel, plastics, and foams. Renowned for quality and precision, DMS advanced machining centers are engineered to increase efficiency and productivity, while maintaining the quality and precision leading manufacturers have come to expect.
Diversified Machine Systems was recently named a 2014 Colorado Company to Watch and was also recognized with the 2013 Regional Business Alliance Excellence in Manufacturing Award.
