Eclipse Magnetics Launch New Cost Saving Filtration System
The unique innovation provides all the time-saving efficiencies of automated cleaning but with vastly reduced investment costs in comparison to other high performance automated filtration systems. It is an affordable solution for OEM projects and can also be retro-fitted seamlessly into existing machining processes.
Automag Compact has a patented high intensity magnetic circuit which extracts potentially damaging ferrous particles - down to sub-micron size, from industrial fluids such as lubricants and coolants. Payback is rapid with improved surface finish, reduced product rejects, increased fluid lifespan, reduced downtime and extended tool life being just some of the many benefits.
The automated cleaning function saves hours of maintenance time and ensures that production is not interrupted. A timed signal activates the cleaning process, the magnetic rods are withdrawn from the filter chambers and the ferrous contamination is purged to a tank or reclaim unit. The whole process takes approximately 10 seconds.
Automag Compact can be supplied with an Eclipse “Skid” fluid recovery system to ensure that the cleaned fluid is returned straight to the process.
The new product is the latest addition to the Eclipse range of high performance automated cleaning filters, now featuring the AMC, AM6 and AM12 units the range caters for flow rates from 200 to 900 litres.
For further information visit www.eclipsemagnetics.com or contact info@eclipsemagnetics.com.
