Westbury, New York — They key to a cost effective preventive maintenance plan are tools that will prevent big leaks before they happen. The Spectroline®OPK-441 Industrial Leak Detection Kit is a starter kit designed to pinpoint the exact source of even the smallest leaks in hydraulic equipment, compressors, engines, gearboxes and fuel systems.
The kit features the OPTIMAX™ 400violet light LED flashlight, a compact, high-intensity unit that quickly reveals all leaks in small to medium-sized oil-based fluid systems — even in cramped areas that are inaccessible to larger lamps.
Also included are is an 8 oz. (237 ml) twin-neck bottle of patented OIL-GLO® 44 concentrated fluorescent oil dye, which is compatible with all synthetic and petroleum-based fluids. When a circulated into a leaking system and scanned with the OPTIMAX 400 flashlight, the dye glows a bright yellow/green at all leak sources to reveal their precise location.
Rounding out the kit is an 8 oz (237 ml) spray bottle of GLO-AWAY™ dye cleaner, dye treatment tags, and fluorescence-enhancing glasses.
Everything come packed in a convenient and durable carrying case for easy storage and retrieval.
The best thing about Spectroline dyes is that you don’t need to waste time or money flushing them away. Because they can safely stay in the system, Spectroline dyes become your most cost-effective method for finding future leaks too.
For more information, call toll-free 1-800-274-8888. Outside the U.S. and Canada, call 516-333-4840 or check us out at Spectroline.com.
