Electrical or Senior Electrical Engineer (Reliability)
About the Pay
Note: The salary range listed ($95,000 - $121,825) reflects the TARGET HIRING RANGE only and does not represent the full pay range for this position.
Electrical Reliability Engineer: $95,000 - $103,251
Senior Electrical Reliability Engineer: $101,483 – $121,825
About the Responsibilities
Working as an Electrical or Senior Electrical Reliability Engineer, you would be exposed to a wide variety of equipment and technical challenges. This may consist of items such as power transformers, power circuit breakers, large synchronous motors and associated systems (excitation controllers, protective relaying, etc.) and low voltage pumping plant ancillary systems.
In this position you will guide CAP in identifying and implementing solutions to technical engineering problems while working to ensure that technical documentation is accurate, complete, and retrievable. You will be a member of multi-disciplined project teams focused on modernizing assets and maintaining reliable water deliveries to CAP customers. A few of the specific responsibilities include:
- Develop, assess and modify equipment maintenance plans based on analytical processes such as reliability centered maintenance, failure modes and effects, root cause failure analysis; and reliability and cost targets.
- Develop and manage asset condition assessment models that use predictive maintenance data to compute condition scores and grades for all major assets.
- Monitor and analyze key performance indicators and metrics relating to the maintenance program for improvement opportunities.
- Consult and communicate with CAP management to develop asset-based budgets and work plans.
- Provide engineering expertise and experience-based knowledge in support of CAP Maintenance, Engineering Resources and Project Management personnel.
About the Qualifications
For the Engineer position: five (5) years of applicable electrical engineering experience with a Bachelor of Science degree in Electrical Engineering or a closely related field; or three (3) years of engineering experience with a Master's in Electrical Engineering is required.
For the Senior Engineer position: eight (8) years of applicable electrical engineering experience with a Bachelor’s degree in Electrical Engineering or a closely related field; or six (6) years with a Master’s degree in Electrical Engineering plus one of the following certifications or licenses:
- Registered Professional Engineer
- Certified Maintenance and Reliability Professional
*Twelve (12) years total Electrical Engineering experience is required for the Senior position if none of the certifications or licenses above are held.
Individuals with utility, heavy industrial, or hydro-electric experience are encouraged to apply.
Please note that this position has some physical requirements and pre-employment physical testing would be required upon offer.
