Emerson Launches Resilient Hybrid Coupling
Developed by the Kop-Flex unit of Emerson’s Power Transmission Solutions business, the design combines a maintenance-free, non-lubricated MAX-C resilient coupling half with a lightweight diaphragm, disc or high-performance gear coupling half, depending on the application. The hybrid design matches the advantages of a low-cost, lightweight flexible coupling half for the driven shaft, with the vibration-damping of a MAX-C coupling half on the motor end. The maintenance-free MAX-C dampens high drivetrain torque loads, while the overall hybrid design reduces weight, cost and inertia, eliminating the need for oversized and costlier drivetrain components. Various designs of the engineered hybrid coupling are capable of transmitting up to 56,000,000 lb-in (6383 kN-m) torque. The MAX-C WB is ideal for use in drivetrains for ID/FD fans, torque converters, marine gears, drill rigs, crushers, kiln drives, mill pinions, ship thrusters, centrifugal compressors, and feed rolls.
The MAX-C coupling consists of an outer sleeve with a bladed ID, an inner flex hub with bladed OD, and resilient drive blocks that fill cavities formed when the sleeve and hub are mated. The special Wedge Block cavity design formed by the blades is filled with incompressible elastomer blocks with a Shore “A” hardness of up to 80, allowing tailoring of the block compound for hardness, chemical resistance and temperature resistance. The blocks typically last five years or more and are easily replaced, which makes the coupling “like new.”
The MAX-C design is also “Fail Engage”: if an elastomer block fails for any reason, the coupling will briefly transmit torque through the metal-to-metal contact of the interlocking blades which would allow the user to immediately power down the equipment in a controlled manner.  The MAX-C withstands wet, gritty and hot environments.
For more details on the MAX-C hybrid see www.emersonindustrial.com or visit the Kop-Flex site at www.emersonindustrial.com/en-US/powertransmissionsolutions/brands/kop-flex for an overview of the company’s product line.
