Engineering Manager - Utilities Asset Management
An Engineering Manager - Utilities Asset Management job is available with the City of Fort Worth Water Strategic Operations’ Facility Planning and Asset Management Section. This section is responsible for strategic frameworks related to vertical facility asset management, facility planning and overarching strategic analytics of the Water department’s facilities. This position will also help in promoting the Utility’s mission, vision and values through the full, cost-effective service life of all assets.
This Position qualifies for the following incentives which is separate from the base pay:
- Sign-On Incentive of $6,500 ***50% paid after the completion of first pay period, 50% paid after the completion of 6 months of employment.***
As the Engineering Manager - Utilities Asset Management, you will need to have a good working knowledge of principles and practices of utility management and operation systems theory. The incumbent should be able to trouble-shoot complex utility systems, conduct extensive research, and provide guidance to internal and external stakeholder groups. This position will report to the Fort Worth Water Department’s Strategic Operations Assistant Director.
Minimum Qualifications:
- Bachelor's Degree from an accredited college or university with a major in civil or mechanical engineering or a related field
- Five (5) years of increasingly responsible in vertical facility asset management
- Two (2) years of administrative and supervisory responsibility
- Possession of registration as a Professional Engineer in the State of Texas. If licensed in another state, continued employment will be contingent upon obtaining registration as a Professional Engineer within the State of Texas within six months of employment
- Valid Driver's license
Preferred Qualifications:
- Additional years of progressively responsible experience in engineering in a water and/or wastewater utility environment including in a management/supervisory capacity
- Experience with Reliability Centered Strategy/Maintenance
The Engineering Manager - Utilities Asset Management job responsibilities include:
- Coordinate with reclaimed customers, manage reclaimed water contracts and collaborate with operations related to reclaimed water system’s operations and maintenance
- Oversee and coordinate risk framework for vertical assets; facilitate department’s wastewater facility master plan
- Lead the facility asset management plan development and closely interact with other divisions within the Utility that use data generated from various systems (i.e. process, energy and hydraulics process)
- Serve on CIP committee and provide analysis and justification for recommended projects
- Utilize the Utility’s CMMS as part of routine activities. Recommend reports, changes, and/or other tools that may be beneficial to the success of the Utility’s Facility AM Program
- Provide technical support to capital delivery project managers assigned to facility capital improvement projects
- Perform conceptual engineering, process diagrams and procurement (spec writing) assistance as needed to support Plant Operations engineering team
- Other duties as assigned
Pay Range: $104,360 - $135,668 annual compensation
Job Posting Closing on: Friday, June 23, 2023
** Sign-On Incentive: $6,500 **
Benefits for this position include: 11 Paid Holidays, Medical, Dental, Vision, Paid Time Off, Pension Plan, Professional Development Opportunities, and much more.
The City of Fort Worth is one of the fastest growing large cities in the U.S. Our employees serve the needs of nearly 1,000,000 residents, promoting our values of exceptional customer experience, mutual respect, embracing our diversity, continuous improvement, ethical behavior, and accountability.
