Fastec Imaging’s TS5 handheld High-Speed Camera enables you to record any rotating machinery or equipment moving at high-speed and susceptible to vibration problems for performance analysis or troubleshooting using slow motion replay. This handheld, portable, battery operated camera with a large built-in LCD touch screen and an intuitive on-screen menu system puts the power of both a traditional high-speed camera and long-record system into the palm of your hand. The TS5 is a true point-and-shoot high-speed camera solution with four models to choose from, boasting crisp, clean video from 2560 x 2080 @ 230fps to 800 x 600 @ 1650fps, there is a TS5 to fit your application needs. All models record over 3200 fps at VGA resolution and more than 18,000 fps at smaller resolutions. Saving images at ultra-fast speed to the onboard media while simultaneously recording high-speed bursts of hundreds or even thousands of images at a time, the TS5 is always ready for the next high-speed snapshot. With a base model starting below $13,000, the TS5 is a cost-effective solution to record high-speed events for slow motion analysis.
Built for flexibility and ease of use, the TS5 can be operated as a self-contained camera or controlled over Gigabit Ethernet via Fastec FasMotion software on your PC/Mac, or via the built-in web interface on your PC, Mac, tablet, or even your smartphone. The FasMotion application makes workflow a breeze with transfers of uncompressed images via Gigabit Ethernet at rates of 50–80MB/s to most PCs. The TS5 features both a USB port and an SD port for quick and easy image downloads to USB flash drives, SD cards, or portable hard drives. The built-in SSD provides up to 1TB of lightning-fast non-volatile internal storage.
Fastec Imaging is a global supplier of digital high-speed imaging systems, based in San Diego, CA. The company specializes in uniquely portable and affordable high-speed camera systems, including handheld point-and-shoot systems, compact PC-controlled cameras, and long duration record systems used in many industries including food & beverage, and chemical manufacturing, packaging, pulp & paper, energy, aviation, ballistics, scientific, academic, athletics, and artistic video production. For more information, visit the Fastec Imaging website at www.fastecimaging.com, email us at info@fastecimaging.com, or call +1 858.592.2342.
