Fluke 64 MAX IR Thermometer Captures Measurements While Unattended, Freeing Maintenance Teams
The new, rugged IR thermometer logs up to 99 data points eliminating the need to manually record measurements
{image:1}
Everett, Wash., May 18, 2017
Temperature events rarely occur while technicians are around to capture them, complicating the troubleshooting of electrical, HVAC, and industrial equipment. The new Fluke 64 MAX IR Thermometer features Auto Capture allowing technicians to set time and intervals to record up to 99 data points unattended so it can capture elusive temperature events. The thermometer can be mounted on a standard tripod using a tripod mount accessory for unattended measurements.
The lightweight, compact, and rugged 64 MAX also features:
  • Precise laser technology for more accurate (up to ± 1° Cor ± 1% of reading whichever is greater) and repeatable measurements;
  • 30 hours of battery life to capture measurements over a long period of time;
  • IP54 rated for extra protection against airborne contaminants in harsh, dirty environments;
  • A flashlight and large, easy-to-read backlit LCD display for easy viewing even in dark settings.
The 64 MAX displays minimum, maximum, or average temperature, or the difference between two measurements, and features Hi and Lo alarms for rapid display of measurements outside set limits. It can survive a three-meter drop and continue to operate, making it ideal for industrial and field environments.
For more information on the Fluke 64 MAX IR Thermometer, visit: www.fluke.com/64max.
Fluke Corporation
For information on Fluke tools and applications, or to find the location of a distributor, contact Fluke Corporation, P.O. Box 9090, Everett, WA USA 98206, call (800) 44-FLUKE (800-443-5853), fax (425) 446-5116, e-mail fluke-info@fluke.com or visit the Fluke Web site at www.fluke.com.
About Fluke
Founded in 1948, Fluke Corporation is the world leader in compact, professional electronic test tools and software for measuring and condition monitoring. Fluke customers are technicians, engineers, electricians, maintenance managers, and metrologists who install, troubleshoot, and maintain industrial, electrical, and electronic equipment and calibration processes.
