Fluke RSE300 and RSE600 Fixed-Mount Infrared Cameras easily integrate infrared data, images & videos
The first fully-radiometric Fluke infrared cameras with MATLAB and LabVIEW software plug-ins deliver continuous temperature monitoring for research, science and engineering applications
Everett, Wash. -- May 22, 2018
For precise research, science, and engineering applications, just seeing heat is not enough — it needs to be measured and analyzed as well. The new Fluke® RSE300 and RSE600 Infrared Cameras are the first fully-radiometric, fixed-mount cameras from Fluke with advanced features including MATLAB® and LabVIEW® software plug-ins to easily analyze thermal data.
The RSE300 and RSE600 cameras continuously stream up-to-60 frames of data per second, allowing for detailed monitoring of temperature patterns and variances. With the included SmartView® desktop software, users can remotely focus the camera, auto-capture images, adjust level and span, and analyze infrared videos frame-by-frame. The software also makes it easy to edit images, generate customized reports, and export images to multiple formats to share thermal data quickly.
With the RSE300 and RSE600 users can:
  • Improve thermal analysis — thermal data from the infrared cameras can be pulled directly into MATLAB and LabVIEW, allowing users to statistically analyze and trend information.
  • Identify heat buildup and dissipation — the cameras capture up to 640 x 480 resolution thermal/radiometric images and video to continuously identify heat buildup, as heat management becomes a priority in product development and testing.
  • Easily test and troubleshoot — the cameras give users the flexibility to strategically mount the unit anywhere there is an electrical connection, remotely focus the camera, and transmit data and images to PC. Semi-fix the cameras to set up easily repeatable thermal experiments to troubleshoot and improve first pass quality.
The rugged cameras are IP65 rated so they can be mounted outside in harsh environments. There are optional 2x and 4x telephoto, wide, and macro lenses to customize for any measurement application. An optional mounting bracket is also available for camera use at workstations.
For more information on the Fluke RSE300 and RSE600 Infrared Cameras, visit: www.fluke.com/rse.
Fluke Corporation
For information on Fluke tools and applications, or to find the location of a distributor, contact Fluke Corporation, P.O. Box 9090, Everett, WA USA 98206, call (800) 44-FLUKE (800-443-5853), fax (425) 446-5116, e-mail fluke-info@fluke.com or visit the Fluke Web site at www.fluke.com.
About Fluke
Founded in 1948, Fluke Corporation is the world leader in compact, professional electronic test tools and software for measuring and condition monitoring. Fluke customers are technicians, engineers, electricians, maintenance managers, and metrologists who install, troubleshoot, and maintain industrial, electrical, and electronic equipment and calibration processes.
