Most machines have rotating parts and those rotating parts vibrate. Measuring how and how much those parts vibrate can tell you a lot about the health of a machine. Whether it’s the rumble of worn bearings or the shaking, shimmying, or thumping of loose, misaligned, or unbalanced parts, machines have a tale to tell those who are willing and able to listen.
The art and science of measuring and interpreting those telltale rumbles and shakes is called vibration analysis and it has been around for decades. Although historically the domain of specialists operating specific instruments for corporations and government agencies with mission critical equipment, vibration analysis is also employed by mechanics using a makeshift stethoscope or similar tool. Vibration analysis on rotating machinery has gained in popularity over more than four decades because thousands of faults can be identified without stopping the machine or tearing the machine down. Recent developments in vibration sensors, data acquisition and analysis technologies, however, are making vibration analysis cheaper, easier and more widely available.
Vibration analysis is a critical component of a condition-based maintenance system. An alternative to the run to failure strategy, condition-based maintenance measures machine health, which doesn’t require tearing a machine down to find out its condition. When a machine condition fault comes up, a repair is scheduled when it’s needed, not before and not too late.
How It Works
Through analyses of patterns and amplitudes of vibration peaks at specific frequencies, rules and algorithms have been developed to diagnose problems with machines. This is accomplished by securely attaching a sensor, typically an accelerometer, to the bearings of a machine and measuring the vibration frequencies that transmit from the rotating shaft through the bearings into the outside metal surface of the machine and then into the sensor.
Among the most important mechanical faults that vibration analysis can reveal are:
Imbalance – A “heavy spot” in a rotating component that causes vibration when the unbalanced weight rotates around the machine’s axis, creating a centrifugal force that causes advanced wear in bearings and seals and wasted energy.
Misalignment – High forces that result when machine shafts are out of line. For example, misalignment forces on the shafts, a motor and pump will cause advanced wear to the bearings and seals, resulting in wasted energy.
Wear – As components, such as bearings, drive belts, or gears, become worn, they may cause vibration. When a roller bearing race becomes pitted, for instance, the bearing rollers will cause a vibration each time they travel over the damaged area. A gear tooth that is heavily chipped or worn, or a drive belt that is breaking down, also can produce vibration.
Looseness – Vibration that might otherwise go unnoticed may become obvious and destructive if the component that is vibrating has loose bearings or is loosely attached to its mounts. Such looseness may or may not be caused by the underlying vibration.
Vibration Analyzer
Pros/Cons
When to use:
For big, complex machines with many variables, such as paper machines, multi-axis machines, turbines, etc.;
For troubleshooting using real-time analysis, bump testing, cross channel phase and resonance testing for faults other than the four common faults previously described.
Vibration Tester
Pros/Cons
When to use:
For most machines with few variables, such as motors, pumps, fans, compressors, blowers, belts and gears;
For diagnosing common machine faults (90 percent): imbalance, misalignment, bearings and looseness;
For technicians that have many other tasks that need to get done and have no time to analyze complex graphs.
Vibration Meter
Pros/Cons
When to use:
To check hundreds of expendable machines and to perform a daily quick check of critical machines in-between testing by the analyst;
For screening all machines 100 percent by using overall vibration, bearing impacts and bearing temperature to determine if a machine is good or bad. The vibration meter is five tools in one, not just one like the vibration pen.
Vibration Pen
(or simply a screwdriver)
Pros/Cons
Vibration pens are easy to use and provide a simple number that represents the overall vibration coming from the machine. However, the number requires knowledge about the machine to determine what the number means. For instance: Is this number bad for this machine? How bad is the fault? What is the fault? and What action is needed?
When to use:
For simple diagnostics of less complex machines.
Vibration Testing Principles
Vibration measurements are not like temperature or voltage measurements. Using electrical test equipment, you might expect to read a number that is repeatable time after time. Using a piezoelectric accelerometer to measure vibration from a dynamic machine train is a different story. That’s because you aren’t measuring the vibration at the source of the vibration, which is the rotating shaft. Instead, you are measuring from the bearing housing of the machine. This means you are really measuring the response of the machine’s structure to the vibration from the rotating shaft inside, the components on the shaft, the bearings, the covers and the foundation. There are many random vibrations mixed in with rotating shaft vibrations. Even the repeatable vibration from the rotating shaft has many variables, such as resonance, speed and load, location, sensor mounting, environment, operational, noise, excitation and other machine influences.
To reduce random vibration, noise and variables:
Make sure the machine is at the same speed and load each time a measurement is taken.
Make sure the machine is running at the same operating conditions.
Make sure the same machines in the area are running at the same operating conditions.
You can do your best to minimize random vibrations and reduce the variables, but vibration spectrum is never going to be exactly the same. The only way you would ever see this kind of repeatability is in a lab environment in space. That’s why using the right tool is so critical because by the time the vibration from the rotating shaft transmits through the bearing to the outside of its housing and into the sensor that is attached with a magnet and mixed with the resonances and noise of the machine, foundation, surrounding structure and adjacent machines, there are just too many variables to expect exact repeatability.
After decades of either primitive (think screwdriver) or extremely unwieldy and expensive vibration analysis, recent developments in the field have enabled a broader application of the practice. Now a critical component of condition-based monitoring programs, vibration analysis continues to evolve, with tools more easily accessible and affordable to the average user.
Case Study:
The Tool that Saved the Dairy
At Alpenrose Dairy in Portland, Oregon, a vibration analysis contractor performing a semiannual check of a critical air compressor warned of bearing deterioration. One of the bearings had gone bad and the maintenance team was advised to take care of it within several months. However, the next week, the air compressor went down, limiting the plant’s production.
At that point, the dairy’s maintenance manager realized the outside contracting firm might not fully understand the workings of the dairy’s equipment. Knowing the ramifications that down equipment could cause, the dairy decided it would be advantageous to have the capability in-house to check its equipment every couple of weeks.
After much research and consultation, Alpenrose Dairy decided to invest in a vibration meter. The maintenance team takes a reading once a month or once a week, depending on the equipment and their findings. If something different is observed, a trend analysis is built with the data. If a change in frequencies is noticed, it is immediately scheduled to be looked at by the maintenance team.
Since it is not economically feasible to test every piece of equipment at the dairy every single month, the maintenance manager prioritizes which equipment to check on a monthly or quarterly basis. Factoring into the decision are the baseline readings from the vibration meter.
By investing in a vibration meter for vibration analysis, Alpenrose Dairy now has a better idea and feel for what’s going on with its equipment.
