GP:50 Corporation Announces Differential Pressure Transducers for Aerospace and Defense Applications
The compact Model 7300 measures just 2.64” x 1.10” x 3.3” (67 mm x 28 mm x 83 mm) and weighs less than eight ounces (0.2 kg). The transducer operates over a standard measurement range of 15 thru 15,000 PSD (1 thru 1,034 BAR), with option to extend upon request. Overall measurement accuracy is <±0.3% FSO (RSS). Burst and proof pressure is 22,500 PSI (1,551 BAR). Standard output configurations include 4-20 mA, 0-5 VDC, 0-10 VDC and mV/V. An optional integral RTD temperature output is also available. Units are designed to reliably operate over a standard temperature range of -20°F to +190°F (-23°C to +82°C), with a compensated temperature range from
-10°F to +190°F (-23°C to +82°C). Each transducer is supplied with NIST traceable calibration to ANSI-Z540-1.
With its small, rugged design and high accuracy, the Model 7300 is ideal for fuel flow monitoring and control; hydraulic systems pressure monitoring; filter condition monitoring; commercial and defense satellites; unmanned aerial vehicle (UAV) testing, aircraft engine testing; in-flight differential pressure measurements, and launch vehicle testing. For more information about the Model 7300 or other pressure transducers for aerospace and defense, please contact GP:50 Corporation LTD on +1.716.773.9300; via email at sales@gp50.com, or visit www.gp50.com.
