Gothenburg, 10 May 2017
As part of the pilot project, SKF’s expertise in bearings, lubrication and condition monitoring will be combined with Honeywell’s capabilities in data consolidation and software development. The project’s ambition is the joint development of a user-friendly digital ecosystem that captures and analyses large amounts of data from a plant operator’s machinery. Based on the analysis of this data, operators will be able to determine methods to reduce or even eliminate manufacturing inefficiencies and unplanned down-time.
Alrik Danielson, President and CEO, SKF, says: “The number of potential data collection points in a modern factory is increasing exponentially, but this data will only generate value for operators if it is analysed and acted upon to improve a machine’s performance and profitability. Our collaboration with Honeywell will make this possible.”
Shree Dandekar, Vice President and General Manager, Honeywell Connected Plant, says: “Leveraging the IIoT gives manufacturers real-time access to operating information from an incrementally larger data-set across not only one site or plant, but across an entire enterprise. By creating an ecosystem of software and hardware manufacturers with unmatched domain experience, we will be able to better understand the risks and demands on the operating units and ultimately provide a higher level outcome for our customers.”
About SKF
SKF is a leading global supplier of bearings, seals, mechatronics, lubrication systems, and services which include technical support, maintenance and reliability services, engineering consulting and training. SKF is represented in more than 130 countries and has around 17,000 distributor locations worldwide. Annual sales in 2016 were SEK 72 787 million and the number of employees was 44 868. www.skf.com
® SKF is a registered trademark of the SKF Group.
