HYDRAULIC INSTITUTE DEBUTS UPDATED STANDARD FOR ROTARY PUMP TESTS
Significant updates include: complete reformatting of the Standard to a one-column layout for easier reading; use of larger graphics and figures; more detailed descriptions, particularly in “Terminology” sections.  Also included is an equation for pump output power.
The new Standard provides most current testing procedures and acceptable deviation of dependent test quantities from specified values for Type III and Type IV testing and is intended for use by all testing facilities.  The objective of ANSI/HI 3.6 - 2010 is to establish a uniform demonstration of a pump’s ability to perform satisfactorily both mechanically and hydraulically.
According to Gregg Romanyshyn, HI Technical Director, “This standard recognizes two levels of performance tests for rotary pumps and provides procedures for conducting and reporting each test level.  The test levels have been designed to permit selection of tolerances and accuracy appropriate for the application and the customer’s needs.  Hydrostatic Test and Net Positive Inlet Pressure Required Test are separate tests and are both optional tests.  Vibration and acoustical testing are not included.”  A number of leading Rotary Pump manufacturers served on the committee that developed this standard, including: Flow Solutions Group, IMO Pump - Colfax, Intelliquip, LLC, Leistritz Corporation, Milton Roy Americas, Moyno, Inc., Roper Pump Company, Siemens Water Technologies, and Weir Floway, Inc.
HI Pump Standards are reliable, widely accepted references for anyone involved in pumps, including users, consultants, contractors, construction firms, manufacturers of pumps, seals, motors, instrumentation, controls, and pump software developers and systems integrators.  HI periodically introduces new Standards based on industry needs.  ANSI/HI 3.6 - 2010, along with HI’s complete library of ANSI/HI Standards for the pump industry, are user-friendly, and available in both electronic and print formats at the HI e-Store: http://eStore.Pumps.org or by calling the Hydraulic Institute’s purchasing line at: 973. 267. 9700 Ext 118.
About the Hydraulic Institute:  The Hydraulic Institute is the largest association of pump producers and suppliers to the pump industry in North America and a global authority on pumps and pumping systems.  Its mission is to serve as a forum for the exchange of industry information, while providing value-added services to member companies and pump users worldwide.  For more information about the Hydraulic Institute, its member companies and Standards Partners visit www.Pumps.org and www.PumpLearning.org.
