Junior Reliability Engineer
JLL is seeking a Junior Reliability Engineer to join our team!
In JLL Work Dynamics our most significant assets are our “People” and our “Clients”. We will act with Dignity and Respect, make Ethical Decisions, champion Corporate Responsibility and serve as a driving force for a Sustainable Asset Management.
There are opportunities for growth and career development, as the team develops you may be responsible for management of junior staff. Acting as a technical subject matter expert you will be supported in achieving external qualifications and becoming globally recognized in RAM.
This exciting opportunity is responsible for providing reliability engineering support for operations and maintenance of buildings, infrastructure, and equipment assets. The purpose of this role is to develop robust analysis in determining reliability of assets, components, equipment, and processes in accordance with JLL’s enhanced Reliability & Asset Management program. Data is extracted from connected systems and used to continually improve maintenance programs to meet outcomes-based performance measures. Moreover, this role oversees root cause failure analysis (RCFA) of equipment failures to determine the required corrective action for the situation including cost avoidance, return on investment, alternative options, and action plans that comply with client intentions to maximize reliability and efficiency of their assets.
Position Responsibility of ESSENTIAL FUNCTIONS:
Recognizes that assignments are broad in nature and require appreciable originality and ingenuity to complete them and considerable latitude for un-reviewed actions or decisions.
Maintenance Planning
  • Prepare work packages for all planned maintenance activities incorporating all safety requirements local to the facility and work being performed.
    • Identify required permits.
    • Determine the proper sequence of work activities.
    • Estimate labor hours needed to perform work.
    • Include estimated costs, including labor, materials, and contract services, for each work order.
  • Identify and develop standard work routines and task lists.
  • Communicate work packages to Maintenance Supervisor via the Weekly Work Schedule.
  • Update asset records in the CMMS as required, including entering new equipment, inactivating retired equipment, and labeling equipment in the field with asset tags.
  • Ensure that all job plans written in the CMMS include detailed instructions with pictures, parts, labor, craft, vendors, regulatory, and safety requirements.
  • Review work order feedback information to improve future planning efforts. Circle back with the trades staff and leads on follow up work, rescheduling requirements, and improvements to the job plan for future work.
  • Maintain library of drawings, manuals, and other documents to assist in maintenance repairs or modifications.
  • Support reliability activities such as root cause analysis investigations, failure mode and effects analysis (FMEA), and preventive maintenance optimization (PMO), as well as assist in developing and implementing precision and predictive maintenance routines.
Reliability Engineering
  • Equipment preventative maintenance (PM) task creation and management for continuous improvement and PM optimization.
  • Supports process of ranking the criticality of the assets under their care, typically using Reliability Centered Maintenance approaches, and for defining the proactive maintenance approaches that are cost-beneficial to the business.
  • Create risk mitigation strategies for critical assets that can be deployed across the asset portfolio
  • Considers impact of costs on recommended action plans for avoiding/correcting problems during the design phase or remedial action for correcting reliability problems on installed equipment; performs root cause failure analysis to help prevent failures.
  • Facilitates/supports operational event and equipment failure investigations to ensure that the root cause/causal factors have been identified, corrective actions prescribed, and follow-up monitoring conducted as applicable, to determine effectiveness.
Condition-based Maintenance
  • Understanding of moving and rotating equipment such as pumps, motors, gearboxes, conveyors, etc., from an operations and maintenance perspective, mechanically and electrically.
  • Experience w/ predictive maintenance technologies including, but not limited to, vibration analysis, oil analysis, infrared Thermography, ultrasound, and motor current analysis.
  • Plans and performs engineering operations, monitors operations center systems, RCM program implementation, process engineering assignments, root cause failure analysis, incorporation of condition-based maintenance (CbM and predictive testing and inspection (PT&I) technologies and conducts equipment condition assessments. Identify and manage system of continuous improvement to ensure resolution to chronic “bad actor” equipment.
  • Experience with Root Cause Analysis, Equipment Criticality Ranking, PM/PdM optimization, Defect Elimination, and/or Failure Modes and Effects Analysis.
Workflow Management
  • Maintain complete and accurate records/plans within computerized maintenance management system (CMMS) related to equipment, specifications data, BOM, failure history, etc.
  • Develop and maintain “Key Performance Indicators" of equipment reliability.
  • Ensure that the appropriate Maintenance and Reliability metrics are in place throughout the site, (planned/unplanned work, planning/scheduling metrics, cost metrics, MTBF, replacement asset value, etc.).
  • Ensure equipment history is maintained and analyzed for future trends
  • Actively collaborate with Maintenance and Planning groups
Performs other work as assigned.
Experience:
  • BS in an Engineering discipline, mechanical or electrical preferred.
  • Formal maintenance planning/scheduling training
  • Minimum 1-2 years’ experience implementing RCM, CbM/PdM methods, operating building automation and energy management systems, and thorough understanding of asset management, data analytics, and capital planning approaches.
  • Experience in critical/ regulated environments preferred (data centers, laboratories, manufacturing environments, automotive, petro-chemicals, pharmaceutical etc.)
  • Extensive knowledge of mechanical, electrical, plumbing and fire suppression systems.
  • Extensive knowledge of commercial, critical, manufacturing, labs, or distribution facility types required.
  • Computer skills and knowledge of various CMMS software
  • Ability to communicate effectively with all levels of the maintenance/operations organization
Skills
  • Proven ability to read, comprehend and apply information from technical manuals and other reference materials
  • Ability to make informed recommendations in situations where data sets may be incomplete
  • Ability to communicate well in both oral and written reports
  • Strong organization skills and ability to multi-task
  • Ability to balance multiple stakeholder requirements
  • Able to interpret how the organizational goals and strategy translate into service or departmental activity
  • Strong Microsoft Excel skills and ability to manipulate large amounts of data accurately using different spreadsheet formats
  • Ability to recognize opportunities for process improvements and assist with implementing them
  • Ability to engage with client/team stakeholders at senior level
  • Ability to distill large/complex challenges in a clear and concise manner
  • Ability to work with team to get the job done
  • Effective communication
Competencies
  • Strong interpersonal skills and collaborative approach – “One Family, One JLL”
  • Energizes others by showing passion and commitment
  • Self-aware; actively seeks, shares and actions feedback on own performance and of team. Advocates self-development
  • A self-starter with flexible and open-minded approach to working and drive to go “Beyond”
  • Systematic approach to work with high attention to detail
  • Ability to work without direct supervision
  • Embraces change and develops innovative solutions and challenges the “status quo”
Certifications & Licenses:
  • Certified Reliability Leader is preferred.
  • Certified Maintenance Reliability Professional is preferred.
  • Level 1 thermography certification is preferred.
  • Level 1 vibration certification is preferred.
  • Level 1 ultrasound certification is preferred.
