Kistler Introduces Miniature PiezoBeam® TEDS Accelerometers for Multi-Channel Modal Testing
The single axis Kistler Type 8640A is the company’s dimensionally smallest, lowest mass PiezoBeam® IEPE accelerometer model, weighing just 3.5 grams. Offered in ranges of ±5 g, ±10 g and ±50 g with sensitivities from 1000 mV/g to 100 mV/g, the sensor’s ceramic cantilever beam sensing element is thermally compensated using patented methods that allow it to emit an electrical charge proportional to vibration (World patent number W0/2007/062532; European Patent: 2006790940; U.S. patent number 12,088,325). The sensing element is enclosed within a hermetically sealed, welded titanium housing with low base strain sensitivity. An internal low noise charge amplifier provides a low impedance output with outstanding amplitude and phase response over a wide frequency range and exceptional measurement stability. The single axis Kistler Type 8640A also features an integral 10-32 connector, as well as several mounting accessories, for easy installation into space constrained environments.
For simultaneous vibration measurements in three orthogonal axes, Kistler offers the Type 8688A precision PiezoBeam® IEPE triaxial modal accelerometer. The Kistler Type 8688A is the company’s dimensionally smallest, lowest mass PiezoBeam® IEPE triaxial accelerometer model, weighing just 6.7 grams (for 1000 mV/g). Available in ranges of ±5 g, ±10 g and ±50 g, with choice of 1000 mV/g, 500 mV/g or 100 mV/g sensitivities, the globally patented Type 8688A (U.S. patent number 12,088,325) incorporates Kistler PiezoBeam® technology, with the ceramic cantilever beam sensing element enclosed within a lightweight, robust, welded titanium housing. Sensing elements are designed to provide outstanding amplitude and phase response over a wide frequency range and are temperature compensated using Kistler’s own patented methods. Type 8688A sensors feature an integral low-noise charge amplifier that converts the charge signal to a proportional high level voltage signal. In addition, Kistler Type 8688A triaxial accelerometers offer an industry standard 4-pin, ¼-28 connector, as well as several mounting accessories, facilitating easy installation into space confined areas, with the ability to mount the sensor on any of its three faces.
Both single axis and triaxial models operate directly from an IEPE power source found in most FFT analyzers, as well as from Kistler Piezotron® power supply couplers or any other industry standard IEPE-compatible power source. Units are ground isolated when mounted with the optional twist-clip or adhesive adapter. For additional details, drawings and specifications, please contact Kistler North America toll-free (in the US & Canada) at 1-888-KISTLER, via email at sales.us@kistler.com, or by visiting www.kistler.com.
About Kistler:
Kistler (www.kistler.com), a Kistler group company, is a supplier of precision sensors, systems and instrumentation for the dynamic measurement of pressure, force, torque and acceleration, as well as related electronics and software serving the automotive, aerospace, industrial, metal processing, plastic injection molding, R&D and testing & evaluation communities. Kistler products, ISO certified since 1994, are well recognized for performance, quality and reliability. With global headquarters in Winterthur, Switzerland and established North American operations since 1955, Kistler’s expansive global sales presence is supported by the activities of 25 group companies and 30 distributors ensuring customer proximity, individualized application support and short product lead times. K-Beam®, PiezoBeam®, Piezotron® and PiezoStar® are registered trademarks of Kistler. All other trademarks are property of their respective owners.
