KlüBer Lubrication Provides Rolling Bearing Grease for Enhanced Protection Against Friction and Wear
Londonderry, NH -- June 9, 2016
Klüber Lubrication, a worldwide manufacturer of specialty lubricants, has announced the availability of Klübertherm HB 88-182, a versatile long-term grease offering good corrosion and wear protection for rolling bearings subject to high loads and medium speeds at temperatures of up to 180°C.
Klübertherm HB 88-182 is fully synthetic and based on a thermally stable base oil, polytetrafluoroethylene (PTFE) thickener and special additives. It closes the performance gap between greases based on perfluorinated polyether (PFPE) oils, which are suitable for high temperature and, for example, conventional high-temperature greases which soon reach their limit when exposed to high thermal loads. With better degradability in the environment than PFPE-based products, the grease is an efficient lubricant with excellent high-temperature properties.
Klübertherm HB 88-182 can be used in rolling bearing applications in corrugating machines, rotary unions, generator bearings, conveyors, hydraulic couplings, smoke extractor motors, and ceramic ovens, as well as cylindrical roller bearings with a high percentage of sliding friction and sealing systems in the automotive industry.
About Klüber Lubrication
Klüber Lubrication is one of the world's leading manufacturers of specialty lubricants, offering high-end tribological solutions to virtually all industries and markets worldwide. Most products are developed and made to specific customer requirements. During its more than 80 years of existence, Klüber Lubrication has provided high-quality lubricants, thorough consultation and extensive services, which has earned it an excellent reputation in the market. The company holds all common industrial certifications and operates a test bay hardly rivalled in the lubricants industry.
