This soft, semifluid coating grease is a certified Environmentally Acceptable Lubricant, recommended for use in applications on or near waterways. It is perfect for oil-to-sea interfaces as well as deck applications. It meets the specifications required by the EPA’s Vessel General Permit; it is readily biodegradable, exhibits minimal aquatic toxicity and will not accumulate in the cells of fish and other aquatic life forms.
Earthwise EAL Wire Rope Grease is an NLGI 0 grease designed to coat wire rope as well as moving chain and cable parts to ensure long life and smooth, quiet operation. Its semi-tacky, water-resistant characteristics enable it to adhere to the application, seal out damaging moisture, protect against rust formation, and shield against acid attack. The formulation includes a robust additive package, including LE’s proprietary Almasol® and Quinplex® additives, to further help the grease protect against wear, corrosion, impact, rust and oxidation.
LE’s R&D team worked hard to come up with a formulation that would fit the bill for an environmentally acceptable lubricant as well as reliably perform in the application. “After extensive field tests, we landed on a product that will help our customers worldwide protect their assets while meeting today’s environmental regulations,” said John Sander, vice president of technology. “Next up, we will broaden the EarthwiseTM line to include additional types of lubricants. We look forward to continuing to help our customers with their lubrication reliability challenges.”.
Click on Image above for Infographic PDF
About Lubrication Engineers
A leader in lubricants since 1951, Lubrication Engineers, Inc., makes reliability easy for its customers, creating solutions for even the toughest lubrication challenges in a variety of industries worldwide. LE boosts profits through longer equipment life, extended service intervals, reduction in energy use, fewer repairs and less inventory. LE’s arsenal includes highly trained consultants, technical expertise, a full complement of reliability products and services, and a comprehensive line of enhanced industrial and automotive lubricants manufactured at its plant in Wichita, Kan. The lubricants are formulated from highly refined or synthetic base oils and proprietary additives, ensuring that they exceed the performance of ordinary oils and greases. Lubrication Engineers operates under an ISO 9001 Certified Quality System.
Call 800-537-7683 or visit www.LElubricants.com for more information about this and other LE products and services, or to find an LE consultant near you.
