LE Introduces Greentastic™ Industrial Cleaner for Fast, Effective Cleanup of Dirt, Grease & Grim
Industrial companies looking for a solution to their tough cleanup jobs have a new solution: Greentastic™ Industrial Cleaner. This powerful liquid concentrate cleaner offered by Lubrication Engineers, Inc. is water-based and contains nine carefully selected and blended active cleaning ingredients – almost twice as many as conventional multipurpose industrial cleaning products. These ingredients work together to provide a robust industrial cleaning solution perfect for many different uses, including oil and grease.
Greentastic Industrial Cleaner is highly effective in a broad range of heavy-duty applications and is gentle enough to be used as a general purpose cleaner. It works for cleaning concrete surfaces, degreasing parts, washing trucks and tractors, cleaning food manufacturing equipment, and a variety of other industrial cleaning applications.
It is also safe and environmentally friendly. Greentastic is phosphate- and phosphorous-free, as well as noncaustic, nonacidic, nonflammable and contains no abrasives.
Easy To Use
Greentastic Industrial Cleaner mixes easily with water or solvents. It takes just 1 gallon of concentrate to make 32 to 64 gallons of cleaning solution for most applications. It is easy to apply with a power sprayer, floor scrubber, mops, cloths or brushes.
As soon as it is applied, it quickly begins working to loosen and dissolve dirt, grease and grime from surfaces. (For directions and mixing ratios for a variety of applications, see the product flyer at www.lelubricants.com/industrial-cleaner.html. The flyer also shows before-and-after photos and test results.)
After the cleaner is rinsed off, the surface will be completely clean and residue-free, with no detergent or solvent film left behind.
Acceptable for Food Manufacturing Plants
Greentastic Industrial Cleaner meets the criteria of a USDA A1 General Cleaner and is suitable and effective for cleaning food processing equipment, as long as standard operating procedures are followed.
About Lubrication Engineers
A leader in lubricants since 1951, Lubrication Engineers, Inc., makes reliability easy for its customers, creating solutions for even the toughest lubrication challenges in a variety of industries worldwide. LE boosts profits through longer equipment life, extended service intervals, reduction in energy use, fewer repairs and less inventory. LE’s arsenal includes highly trained consultants, technical expertise, a full complement of reliability products and services, and a comprehensive line of enhanced industrial and automotive lubricants manufactured at its plant in Wichita, Kan. The lubricants are formulated from highly refined base oils and proprietary additives, ensuring that they exceed the performance of ordinary oils and greases. Lubrication Engineers operates under an ISO 9001 Certified Quality System.
Call 800-537-7683 or visit www.LElubricants.com for more information about this and other LE products and services, or to find an LE consultant near you.
