Leaks in Oil-Based Fluid Systems Can’t Hide from this Powerful Industrial Leak Detection Kit
The kit features the OPTI-LUXTM 400 violet light LED leak detection flashlight. It has power comparable to high-intensity 150-watt lamps. The unit is compact, lightweight and rechargeable. Its high-output violet light enables dyes to fluoresce more brilliantly and with greater contrast than with standard blue light inspection lamps.
Also included in the kit is a 16 oz (473 ml) twin-neck bottle of patented OIL-GLO® 44 concentrated oil dye, which is compatible with all synthetic and petroleum-based fluids. When a leaking industrial system is scanned with the OPTI-LUX 400, the dye glows a bright yellow/green color to reveal the precise location of all leaks each and every time.
Rounding out the kit is an 8 oz (237 ml) spray bottle of GLO-AWAYTM dye cleaner, a smart charging cradle with AC and DC cord sets, dye treatment tags and fluorescence-enhancing glasses. All components are conveniently packed in a rugged carrying case.
For more information, call toll-free 1-800-274-8888. Outside the U.S. and Canada, call 516-333-4840. Website at www.spectroline.com.
