Listening to Your Gear Reducer
Do you know what to listen for when inspecting your gearbox/reducers? Listen for abnormal noise. Noise inspection should focus on change in sound. Use an industrial stethoscope if necessary. If you don't have a stethoscope, you may also use a wooden stick to listen for noise.
Excessive noise may be due to:
  • Misalignment
  • Poor lubrication
  • Worn/Failed Bearings
  • Worn/damaged Gear teeth
Although gear-reducer is making noise, make sure that condition is not caused from other system problems, such as:
  • Fluctuation in drive speed
  • Coupling wear
Learn more about the what/why/how of equipment care.
Tip provided by:
