LumaSense Introduces the First Industrial Grade Infrared Pyrometer with Thermal Imaging Capabilities
The system is based on the proven ISR 6 Advanced pyrometer and a video camera that utilizes a short wavelength infrared filter. The resulting ISR 6-TI Advanced system operates in a short wavelength (around 1 μm) for accurate and reliable temperature measurements between 700 °C and 1800 °C. The analog video output signal is converted to USB and fed to a PC using LumaSense’s InfraWin software. The InfraWin software generates and shows a “Relative” thermal image from this signal. LumaSense’s InfraWin software also provides temperature, data logging, and analysis features. The ISR 6-TI Advanced paints a more-accurate picture for identifying potential issues before they lead to problems that impact process performance, a key benefit for materials manufacturers running heat-dependent processes.
“The ISR 6-TI Advanced solution is ideal for industries where it’s critical to know the temperature of an object as well as ensure uniformity across an object at that temperature,” said Daniel Schueftan, Product Manager for Pyrometry at LumaSense Technologies. “It is accurate and easy to use by offering a single user interface for the pyrometer and thermal imaging function. The key advantage here is that there is no mechanical alignment required between the thermal image and the pyrometer, creating a seamlessly integrated system. As such, many processes in metals and glass making industries that use a single pyrometer to measure temperature can be improved with this innovative technology.”
The ISR 6-TI Advanced makes its debut next week at the Heat Treatment Congress, a major exhibition for heat-intensive manufacturers on October 22 - 24 in Cologne, Germany. The ISR 6-TI Advanced can also be viewed at MEORGA, an exhibition for process control systems, measurement and control technology on November 5, in Bochum, Germany.
