Luneta Launches Breakthrough Lubricant Inspection Pod
The CMP boasts a robust platform of 16 capabilities (10 of which are uniquely exclusive to this innovative tool). These along with other features deliver ultimate versatility:
  • Built-in oil sampling port
  • Easy-to-remove-and-view magnetic plug
  • Corrosion/ varnish inspection probe
  • Quick lubricant access point for syringe sampling
Best applications include gearboxes, bearing oil sumps, hydraulic reservoirs, compressor oil reservoirs, turbine-generator main oil tanks and paper machine central reservoirs.
“We believe that Luneta has re-invented the sight glass by turning it into the focal point of machine condition monitoring,” said Luneta CEO Tom Fitch. “The Condition Monitoring Pod makes oil analysis as simple as performing daily machine inspections. A sight glass should not be limited to simple oil level inspections. Instead, with the CMP, an array of critical machine and lubricant conditions can be examined in just seconds. And, it signals the beginning of Luneta’s vision to enhance machine reliability through the development of groundbreaking inspection technologies.”
The Condition Monitoring Pod retails for $289 and is available for purchase on Dec. 16, 2013 at Luneta.com or by emailing the company at sales@luneta.com
