Meggitt Introduces Sensorex Harsh Environment Closed Loop Servo Inclinometers/Accelerometers
Available in 12 individual models per series, with angular measurement ranges from ±3° to ±90°, and choices of single axis (SX41200) and twin axis (SX41400) versions, their highly rugged design incorporates a galvanometric pendulum sensing element with hydromechanical damping, combined with an optical position sensor, with 4-20 mA or ±5 VDC (±5%) output, proportional to sine of the angle of tilt. Inertial sensing elements are contained within rugged, watertight IP65 sealed aluminum housings for added durability. They are powered by a single, unregulated voltage supply and feature a bidirectional output. Additional options, available upon customer request, include a ±0.02% non-linearity error specification (excluding ±90° range), special bandwidth, zero offset (unipolar output) and special range and output signals. In addition, all Sensorex SX41200 and SX41400 series models conform to both European EMC and railway testing standards.
The series are ideal for high-precision angular or acceleration measurements within structural alignment, offshore platform safety, railway leveling and monitoring, radar antenna positioning, and ship roll and pitch applications, as well as offshore barge ballast transfer systems, bore-hole mapping, geophysical measurements, level control and calibration systems, marine environment tilt measurements, crane overturning moment alarms, and large machinery installation and electronic leveling. All Sensorex SX41200 and SX41400 series models are also accompanied by a two-year comprehensive product line warranty. For detailed specifications, drawings or more information, visit www.sensorex.fr or www.meggittsensingsystems.com.
About Meggitt Sensing Systems
Meggitt Sensing Systems, a Meggitt group division (www.meggitt.com), is a leading supplier of high-performance sensing and monitoring systems for physical parameter measurements in extreme environments. It has operated since 1927 through its antecedents-ECET, Endevco, Ferroperm Piezoceramics, Lodge Ignition, Sensorex, Vibro-Meter and Wilcoxon Research-whose portfolios form the basis of product lines offered by today’s Meggitt Sensing Systems. Meggitt’s Endevco range of piezoelectric, piezoresistive, Isotron and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications. Endevco and Isotron are registered trademarks of the Meggitt group. All other trademarks are property of their respective owners.
