Meggitt Sensing Systems Announces Launch of Endevco® Three-Channel PE/IEPE Signal Conditioner
This model is designed with a flexible setup and a wide bandwidth to 230 kHz (+/-5%), allowing it to be used with Endevco®  PE and IEPE accelerometers, or other industry models, across a variety of general purpose laboratory testing applications.
The Endevco® model 123 incorporates a charge amplifier when used with PE sensors, and an integral 0, 4 or 10 mA, per channel selectable current source is utilized with IEPE sensors. The unit also features a front panel user interface that allows the programming of Input Sensitivity and Output Sensitivity to calculate the amplifier gain.  Gain settings can also be entered in directly on a per channel basis.  Optional plug-in, 4-pole Butterworth high pass and low pass filter modules are available.  BNC output connectors allow for easy hookup to readout and recording instrumentation.
Common applications for a measurement system which includes the Endevco® model 123 PE/IEPE signal conditioner, along with appropriate sensors, include modal and structural analysis, NVH, automotive and aerospace testing and general in-laboratory applications. In addition, all Endevco® signal conditioners are accompanied by a five-year comprehensive product warranty.  For more information about the model 123 or other products available from Meggitt Sensing Systems, visit www.meggittsensingsystems.com.
About Meggitt Sensing Systems
Meggitt Sensing Systems, a Meggitt group division (www.meggitt.com), is a leading supplier of high-performance sensing and monitoring systems for physical parameter measurements in extreme environments. It has operated since 1927 through its antecedents—ECET, Endevco, Ferroperm Piezoceramics, Lodge Ignition, Sensorex, Vibro-Meter and Wilcoxon Research—whose portfolios form the basis of product lines offered by today’s Meggitt Sensing Systems. Meggitt’s Endevco® range of piezoelectric, piezoresistive, Isotron® and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications. Endevco® and Isotron® are registered trademarks of the Meggitt group. All other trademarks are property of their respective owners.
