Meggitt Sensing Systems Announces Vibration Amplifier for Jet Engine and APU Testing
San Juan Capistrano, California, USA – Meggitt Sensing Systems, a Meggitt group division, has announced the successful application of the Endevco® 6634C vibration amplifier in meeting the rigorous demands of jet engine testing and aircraft auxiliary power unit vibration measurements.
The Endevco® 6634C is a microprocessor-based vibration amplifier, designed to condition and display rotating machinery data while offering simultaneous outputs as broadband, acceleration, velocity and displacement. The Endevco® 6634C is designed to accept inputs from a single-ended, differential piezoelectric or ISOTRON® (IEPE) accelerometer, velocity coil or remote charge converter. Full-scale AC and DC output ranges, as well as sensitivity, are user programmable in selectable engineering units and are representative of acceleration, velocity or displacement. Programming is accomplished from the front panel keyboard or optional RS-232 computer interface. Units also have an optional six-pole filter, which may be programmed from the front panel. Up to ten unique setups can be stored and recalled from the non-volatile memory, while two TTL- compatible latched alarm outputs provide both warning and alert functions. An optional 19-inch mounting rack, also available from Meggitt Sensing Systems, can accommodate up to six units.
With its unique versatility to accept and condition multiple transducer output types, the Endevco® 6634C vibration amplifier is ideal for the turbine and generator health monitoring of jet engines, generators, turbines and pumps. They are also well-suited for aerospace engine test cell applications which further incorporate the use of high-temperature accelerometers, or where vibration data is required to be expressed in terms of velocity. These rugged units may also be used with other balanced differential output devices. Additional applications include fixed and mobile test cells for small turbofans, air cyclers, as well as in-laboratory test rigs.
The Endevco® 6634C vibration amplifier is also backed by a five-year comprehensive product warranty, with quantities available for immediate customer shipment. For additional information about the Endevco® 6634C or other products available from Meggitt Sensing Systems, visit www.meggittsensingsystems.com.
About Meggitt Sensing Systems
Meggitt Sensing Systems, a Meggitt group division (www.meggitt.com), is a leading supplier of high-performance sensing and monitoring systems for physical parameter measurements in extreme environments. It has operated since 1927 through its antecedents—ECET, Endevco, Ferroperm Piezoceramics, Lodge Ignition, Sensorex, Vibro-Meter and Wilcoxon Research—whose portfolios form the basis of product lines offered by today’s Meggitt Sensing Systems. Meggitt’s Endevco® range of piezoelectric, piezoresistive, Isotron® and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications. Endevco® and Isotron® are registered trademarks of the Meggitt group. All other trademarks are property of their respective owners.
