Meggitt Sensing Systems Debuts World’s Smallest Triaxial Isotron Accelerometer
Offering a low impedance output, shear mode construction and weighing just 1.1 grams without cable, the adhesive mounted Endevco model 35A is designed as a complete measurement package to reduce the unwanted effects of mass loading on more delicate test structures. Sensor output is transmitted through the same wires that supply required 4 mA constant-current power. The model comes pre-installed with both field repairable and factory replaceable fine gage wires (34 AWG) as output leads. Model 35A includes the Endevco model 3027AM5-120 cable with pigtails at one end to connect to the pre-installed accelerometer wires and three BNC connectors at the other end. A removal tool is also provided.
With its extremely small size, the Endevco model 35A is ideal for the shock and vibration testing of electronic components and equipment; automotive component vibration monitoring; scale model vibration testing; and biomedical research. For detailed technical specifications, drawings or additional information, visit www.meggittsensingsystems.com.
