Meggitt Sensing Systems Introduces Endevco Micro-miniature “Flip-Chip” MEMS Pressure Tra
Offered with a 0 to 15 psia range and with 200 mV full-scale output (with 5 Vdc sensor excitation), the highly compact Endevco® model 40931 measures just 1.65 mm long by 1.2 mm wide by 0.4 mm tall. A uniquely sculptured silicon diaphragm design provides high sensitivity, high overpressure capability and a combined 0.5% non-linearity, non-repeatability and hysteresis specification, making it one of the most accurate pressure transducers of its size and type on the market today. Four connection pads allow for the sensor to be “flip chip” mounted to a circuit or substrate using conductive epoxy. The MEMS pressure sensing element, located on the top of the sensor package, enables surface mounting and serves as the active sensing element for absolute pressure measurements.
All sensing elements for the Endevco® model 40931 are machined in-house at Meggitt’s own ISO9001 certified MEMS facility in Sunnyvale, California, USA, where vertically integrated manufacturing processes allow for full control of product quality, from component through to finished product.
For detailed technical specifications, drawings or additional information, visit www.meggittsensingsystems.com.
About Meggitt Sensing Systems
Meggitt Sensing Systems, a Meggitt group division (www.meggitt.com), is a leading supplier of high-performance sensing and monitoring systems for physical parameter measurements in extreme environments. It has operated since 1927 through its antecedents-ECET, Endevco, Ferroperm Piezoceramics, Lodge Ignition, Sensorex, Vibro-Meter and Wilcoxon Research-whose portfolios form the basis of product lines offered by today’s Meggitt Sensing Systems. Meggitt’s Endevco® range of piezoelectric, piezoresistive, Isotron® and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications. Endevco® and Isotron® are registered trademarks of the Meggitt group. All other trademarks are property of their respective owners.
