Meggitt Sensing Systems Introduces Endevco Piezoelectric Accelerometer
Featuring a lightweight sensor design which allows for high seismic resonance and ruggedness within the same package, Endevco® model 7240C offers low base strain sensitivity and excellent output stability over time, with a total package weight of just 4.8 grams, effectively eliminating mass loading concerns. The unit is hermetically sealed to prevent against environmental contamination and is a self-generating device which requires no external power source for operation.
Signal ground of the Endevco® model 7240C is connected to the outer case of the unit. When used with one of the supplied isolated mounting studs, the accelerometer is electrically isolated from ground. A specially designed low-noise coaxial cable is also supplied for error-free operation.  The sensor’s overall size, versatility and performance make it ideal for use within a variety of automotive, aerospace, commercial aviation, general laboratory testing and structural monitoring applications.
Recommended optional accessories for use with the Endevco® model 7240C include the model 133 three-channel signal conditioner; the new model 2771C-XX series in-line charge converter; and the model 3053VM1 HyperFlex cable assembly, all available from Meggitt Sensing Systems. In addition, all Endevco® sensors and instrumentation are accompanied by a comprehensive five-year product warranty. For more information about the model 7240C or other products available from Meggitt Sensing Systems, visit www.meggittsensingsystems.com.
Meggitt News Image
About Meggitt Sensing Systems
Meggitt Sensing Systems, a Meggitt group division (www.meggitt.com), is a leading supplier of high-performance sensing and monitoring systems for physical parameter measurements in extreme environments. It has operated since 1927 through its antecedents-ECET, Endevco, Ferroperm Piezoceramics, Lodge Ignition, Sensorex, Vibro-Meter and Wilcoxon Research-whose portfolios form the basis of product lines offered by today’s Meggitt Sensing Systems.  Meggitt’s Endevco® range of piezoelectric, piezoresistive, Isotron® and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications. Endevco® and Isotron® are registered trademarks of the Meggitt group.
