Meggitt Sensing Systems Introduces Miniature Triaxial Accelerometers for Electronics Testing
Offering industry best-in-class low-impedance output for its dimensional size, the shear mode Endevco® 35A provides a complete measurement package for the collection of IEPE acceleration data across three orthogonal axes. The integral internal amplifier of the model 35A converts high-impedance accelerometer charge input into low-impedance voltage output. Output is transmitted through the same wires that supply required 4 mA constant current power. Signal ground is connected to the outer case. The unit is delivered with pre-installed fine gauge (34 AWG) wires as output leads, all of which are easily field repairable. A new lead assembly may further be factory reinstalled. Also included is the four-conductor Endevco® 3027AM5-120 cable terminating in three BNC connectors. The cable is shipped as an accessory for installation by the customer. A tool is also provided for easy field installation and removal. Units weigh just 1.1 grams without cable and are adhesive mounted for minimized mass loading.
With its extremely small size, the Endevco® 35A is ideal for the triaxial shock and vibration testing of electronic components and equipment; scaled model vibration; automotive component vibration monitoring; and biomedical research. It is also a popular choice for the analysis of engine rotor and stator blades. The unique size, output and triaxial measurement capabilities of the 35A allow for blade modes to be studied at various rotating speeds, assessing mutual interaction between rotor and stator during pass-by, with the unique advantage of measuring both bending and torsion motions of a single blade acceleration vector.
For detailed technical specifications, drawings or additional information, please visit www.meggittsensingsystems.com.
About Meggitt Sensing Systems
Meggitt Sensing Systems, a Meggitt group division (www.meggitt.com), is a leading supplier of high-performance sensing and monitoring systems for physical parameter measurements in extreme environments. It has operated since 1927 through its antecedents—ECET, Endevco, Ferroperm Piezoceramics, Lodge Ignition, Sensorex, Vibro-Meter and Wilcoxon Research — whose portfolios form the basis of product lines offered by today’s Meggitt Sensing Systems. Meggitt’s Endevco® range of piezoelectric, piezoresistive, Isotron® and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications. Endevco® and Isotron® are registered trademarks of the Meggitt group. All other trademarks are property of their respective owners.
