METTLER TOLEDO Introduces PROFINET IO® Interface Option for Popular Weighing Terminal
The popular IND780 weighing terminal from METTLER TOLEDO is now available with an optional PROFINET IO® interface and most existing weighing installations using IND780 can be upgraded to PROFINET IO® connectivity. This news is also important for businesses that would like to extend the lifetime of their weighing equipment when network technology has been modernized.
The IND780 with the PROFINET IO® interface has received a conformance certificate from a PI test laboratory, ensuring conformance to the latest specification for PROFINET IO® devices.  A General Station Description file, as a sample for Siemens Step 7 PLC interface code for use with IND780 PROFINET IO®, is available from METTLER TOLEDO to assist with weighing terminal implementation.
The IND780 provides interfaces for up to four independent measuring channels for scales or flow meters. In addition, IND780 provides a wide range of communications interfaces, including 4-20ma output, serial, Ethernet TCP/IP, and USB.  A simple operating system with an enhanced graphical display and SmartTracTM, the IND780 improves the speed and accuracy of manual or semi-automatic operations with three display modes that relate weight status to target graphically.
Further details on the IND780 weighing terminal can be found at http://www.mt.com/IND780.
About METTLER TOLEDO
METTLER TOLEDO provides the enabling technology, software and people that can help build a seamless workflow to translate bench scale chemistry into a commercial process. For more than 20 years, our enabling tools and services have been a strategic resource providing critical information for thousands of development scientists and engineers. Companies have used that knowledge to accelerate the discovery, development and scale-up of new chemical processes spanning the chemical and biopharmaceutical industries. For more, visit Mettler Toledo website
