Utilizing a short wavelength spectral response of 2 to 2.6u, the Sirius SI23 is a perfect choice for induction heating, steel and metal heat treat processes, kilns, vacuum furnaces, research and development applications, welding and composite temperatures above 50°C. Sales Manager, Scott Nagle states, “Since the emissivity of metallic or shiny surfaces decrease with shorter wavelengths and the SI23 operates at short wavelength, it is therefore able to offer much better repeatability and accuracy performance than pyrometers with longer wavelengths.”
As standard, the high performance Sirius SI23 is offered with PSCWin Software for recording, analysis, and adjustment of all pyrometer parameters. Accessories include a water-cooling jacket, air purge, scanning mirror, adjustable mounting bracket and swivel base mount.
Process Sensors Corporation offers a wide range of simple to sophisticated, non-contact infrared temperature sensors, thermal imaging / thermal line scanning systems, and blackbody calibration sources to meet the most demanding on-line industrial process applications and OEM performance requirements.
Detailed specification information can be found at www.processsensorsIR.com.
Process Sensors Corporation is a private company with a manufacturing facility and corporate headquarters located in Milford MA, USA. The company is a manufacturer and distributor of non-contact temperature sensing and moisture measurement instruments, and the associated calibration systems. Technical and application support is provided worldwide through direct, regional and sales representative offices.
