New Addition to the Reusable MEMOLUB Automatic Lubricator Line of Products
The new MEMOLUB ONE LPS utilizes the same reliable patented positive displacement pumping system as the MEMOLUB HPS but, with reduced output pressure, is specifically designed for single point lubrication. The simple MEMO system, used to set the programming of the MEMOLUB ONE LPS, eliminates the risk of inadvertently changing the lubricant output frequency setting, thus avoiding human error. MEMOLUB ONE LPS can be remotely mounted up to 6 feet from the lube point, minimizing the danger of accessing critical points. The low cost, easy-to-change, replaceable lubricant cartridge (available with the customer’s choice of grease or oil) and battery pack are the only consumables required, reducing not only the environmental impact, but also the ongoing cost of use when compared to other similar systems.
PLI, LLC
PO Box 044051
Racine, WI 53404
(800) 635-8170
Fax (262) 637-4090
website: http://www.memolub.com e-mail: sales@memolub.com
