New Kop-Flex Service Program Recertifies Used, High-Performance Couplings to API 671 Standard
Emerson’s Power Transmission Solutions introduces a new program for restoring used high-performance couplings to like-new condition, certified to API 671, with a full original factory warranty. Ideal for high-speed (>1,800 rpm) couplings used on turbomachinery, compressors, pumps and marine drivetrains, the Kop-Flex recertification program is a low cost alternative to replacement of a coupling, for just 50 to 60 percent of the cost for a new unit. “It is also an excellent option for adding a low-cost spare to a plant’s stores,” said Dan Phillips, Kop-Flex Global Manager, Metals Industry Service. “This is not a repair program, but more like factory service for a high-mileage car, except you get a new-car warranty and performance at the end.” The recertification program applies to all Kop-Flex disc, diaphragm and gear couplings, and the company’s four global service centers provide processing of most couplings in four weeks or less.
The program includes comprehensive mechanical/metallurgical evaluation with MPI and dye-penetrant testing; updating to all current standards; glass bead blasting and hand polishing; replacement of wear parts such as disc packs, shims, and fasteners; precision dimensional and TIR measurement; rebalancing to original API 671 or 610 specs and return shipping in a custom crate. Glass bead blasting eliminates the need for machining/metal removal that might cause a need for shimming during reinstallation.
The recertification program requires return of the entire coupling structure. Couplings not originally produced by Kop-Flex are accepted on a case-by-case basis for limited services.
For information on KOP-FLEX’s recertification program for high-performance couplings, contact Technical Service at 800-626-2093 or visit www.Kop-Flex.com
About Emerson
Emerson (NYSE: EMR), based in St. Louis, Missouri (USA), is a global leader in bringing technology and engineering together to provide innovative solutions for customers in industrial, commercial, and consumer markets around the world.  The company is comprised of five business segments: Process Management, Industrial Automation, Network Power, Climate Technologies, and Commercial & Residential Solutions.  Sales in fiscal 2013 were $24.7 billion.  For more information, visit www.Emerson.com
About Emerson Industrial AutomationTM
Emerson Industrial Automation, a business of Emerson, provides automation and power generation technologies and services to a wide range of industries. With its global capabilities and deep industry expertise, Emerson Industrial Automation is a trusted partner for products and solutions that increase machine performance, efficiency, reliability, and availability. Its industry-leading brands include Appleton®, ASCO®, Branson®, Browning®, Control Techniques, Jaure®, Kop-Flex®, Leroy-Somer®, McGill®, Morse®, Numatics®, O-Z/Gedney, Rollway®, SealMaster®, and System PlastT.  For more information, visit powertransmissionsolutions.com
