The ONT-365 system features four broad-beam lamp heads. Each has three ultra-high-flux UV-A (365nm) LEDs for NDT inspection and one white light LED for general illumination. This unique lighting system allows inspectors to move the lamp heads anywhere along the tracks so that beam patterns can be made to fit specific needs. Lamp heads can even be added for increased area coverage.
The ONT-365 light sources produce a nominal steady-state UV-A intensity of 9,000 µW/cm² at 15 inches (38 cm). An optional attenuating filter is available for reduced intensity applications. Electronic Intensity Stabilizers ensure consistent UV LED performance during extended use, and built-in cooling fans moderate temperature. The “instant on” operation of the lamps enables them to reach full intensity immediately. The LEDs have a rated life of 30,000 hours.
The ONT-365 system comes complete with UVS-30 UV-absorbing spectacles. Additional lamp heads and an optional remote control with a three-position rocker switch are sold separately.
For more information about the Spectroline® ONT-365 On-TrakTM NDT Inspection System, call toll-free 1-800-274-8888. Outside the United States and Canada, call 516-333-4840. Website at www.spectroline.com.
