New Monitoring Program Helps Protect Rolling Mill Drives for Safe Increases in Mill Loads
Emerson Power Transmission Solutions is launching a new torque-amplification analysis program for precisely measuring the true torque loads and vibration frequencies experienced by rolling mill drives, as part of a program to help mills process tougher alloys, increase output with thicker slabs or higher speeds, protect against cold-end slabs, or mitigate torsional vibration. Developed by Emerson’s Kop-Flex business unit, the new torque amplification analysis program combines computer modeling of complex drives with true torque measurements to determine the actual torque amplification factor (TAF) on the drive, instead of inferring it from motor current readings. Kop-Flex then engineers solutions that reduce TAF and torsional vibration using alterations of coupling stiffness, improved overload protection, resilient couplings and other strategies.
“TAF can be defined as the peak torque divided by the rolling torque,” explained Dan Phillips, Kop-Flex Global Manager, Metals Industry Service. “It’s a unit-less factor that shows the severity of a torque spike. It is affected by system dynamics or how the inertias and stiffnesses are distributed across a complex drivetrain. Entry conditions, such as slab temperature, speed, angular clearances and backlash in gear components all play a role. The old rule of thumb for mill drives was to keep the TAF under 2.5, but with motor sizes increasing, slab thickness increasing and new alloys being processed, the old rules don’t apply. As rolling torque increases, so will peak torque, degrading overload protection devices, bearings, couplings, work rolls, etc. Often the first sign of a torsional problem is equipment failure.”
TAF analysis applies measured torque readings to 3D mode shape analysis to visualize how a drive train twists at various locations to determine where to alter stiffness or increase damping. “We use torque monitoring hardware developed for high-speed turbomachinery drives, so it is already mill-hardened, accurate and capable of high-rate data sampling,” said Phillips. “High-rate sampling using strain gages allows the system to capture torque spikes that would normally be unseen on motor current readings because of the high-inertia in these drives. At lower sampling rates, peak torque measurements are often truncated because the system cannot capture them. High-rate sampling is a must to capture these events in a complex, high-inertia drive.”
According to Phillips, Kop-Flex has used the technology to engineer TAF reductions as high as 50 percent.
TAF data capture and analysis can be a temporary service or it can be integrated with a mill’s CSI6500 condition monitoring system as an ongoing service. The CSI6500 system from Emerson Process Management is widely used in the steel industry to track bearing vibration, temperature and other data. Additional data on torque loads allows the mill to correlate the measured torque with slab temperature, force on the work rolls, speed, gap, etc., so engineers can better understand the root cause and make needed changes on scheduled downtime, before cumulative damage leads to an unscheduled outage.
Receive more information on this program by calling Kop-Flex at 1‑410-768-2000.
About Emerson
Emerson (NYSE: EMR), based in St. Louis, Missouri (USA), is a global leader in bringing technology and engineering together to provide innovative solutions for customers in industrial, commercial, and consumer markets around the world.  The company is comprised of five business segments: Process Management, Industrial Automation, Network Power, Climate Technologies, and Commercial & Residential Solutions.  Sales in fiscal 2013 were $24.7 billion.  For more information, visit www.Emerson.com
About Emerson Industrial AutomationTM
Emerson Industrial Automation, a business of Emerson, provides automation and power generation technologies and services to a wide range of industries. With its global capabilities and deep industry expertise, Emerson Industrial Automation is a trusted partner for products and solutions that increase machine performance, efficiency, reliability, and availability. Its industry-leading brands include Appleton®, ASCO®, Branson®, Browning®, Control Techniques, Jaure®, Kop-Flex®, Leroy-Somer®, McGill®, Morse®, Numatics®, O-Z/Gedney, Rollway®, SealMaster®, and System Plasttm.  For more information, visit powertransmissionsolutions.com
