New SKF SYSTEM 24 LAGD Series single-point automatic lubricators deliver accuracy, reliability
Compared with manual lubrication, the automatic lubricator’s continuous and controlled supply of fresh and clean lubricant minimizes the ingress of potentially damaging contaminants, prevents the overheating, waste, and seal damage caused by over-lubrication, and eliminates excessive wear from over-lubrication.
The lubricator features flexible and user-adjustable dispense settings (ranging up to 12 months) and transparent lubricant containers for visual inspection of dispense rate. A patented gas cell generates the proper pressure to dispense lubricant consistently from containers filled with SKF high-quality lubricant specially formulated for the application. Custom lubricant fills can also be evaluated upon request. Users can additionally benefit from the unique SKF DialSet program (available free for downloading from www.skfusa.com) to determine precise lubricant-dispensing calculations.
LAGD Series lubricators are supplied ready-to-use in two sizes (60 ml and 125 ml) and integrate tool-free activation. Various lubricator accessories, including connectors, brushes and no-return valves (for oil applications), and mounting and protecting devices can be specified.
