New Torque Wrench Kit Designed For Plumbing and Utility Flexibility
This compact kit gives plumbers and utility workers all the tools they need to properly tighten all standard fastening screws on No-HUB couplings to either 60 or 80 lb-in.
Each kit comprises two Lowell T-Torker torque wrenches and three hex sockets (1/4”, 5/16”, and 3/8”). A durable carrying case is available.
One of the wrenches is factory preset to 60 lbs. max torque and the other to 80 lbs. When maximum torque is reached during the tightening process, each wrench will slip to prevent overrunning. The presets cannot be user-modified.
Each wrench is labeled with its torque setting and each has a color coded collar for easy identification, even in low light conditions.
Based on Lowell’s ratchet technology, the torque wrenches offer fast, one-handed tightening in the right hand direction to set values that are accurate to ±10%.
The wrenches are designed for maximum efficiency and ease of use. Compact size and light weight ensure hand comfort. The T-shaped handle gives a user good leverage and a flanged collar can be easily pulled to disengage the ratchet mechanism and lock the tool for effective reversing action, without torque limitation.
All mechanisms are sealed in the die-cast handle and lubricated for the lifetime of the tools.
Like all of the company’s products, Lowell’s torque wrenches are guaranteed against defects in material and workmanship for a period of one year from date of delivery.
Started as the Lowell Wrench Company in 1869, Lowell Corporation is a leading American manufacturer of ratchet technology for hand tools and machinery. The company makes ratchet arms, socket wrenches, ratchet and roller clutches, and related products used by civilian industry, the military, and utilities. Lowell sells its products both nationally and internationally.
For more information about Lowell’s torque wrenches, or for a full-line catalog, call 800/456-9355 or 508/835-2900, email customerservice@lowellcorp.com,  or visit the company’s web site: www.lowellcorp.com.
