New V760EX Vertical Lathe Provides Stable, High-Precision Cutting in a Small Footprint
Okuma will introduced its new V760EX vertical lathe, an update to the popular V60R model at IMTS 2014. This new version provides a larger work envelope in the same footprint, allowing for an additional 110mm in workpiece height and an additional 150mm maximum turning diameter.. It provides stable, high-precision cutting in a small footprint and is an excellent platform for machining thin and odd-shaped work pieces, and is well suited for the oil and gas and aerospace industries.
The V760EX vertical lathe has powerful cutting capabilities, a class leading working range, and excellent ergonomics. The box way system and rock solid base and column provide a highly dependable, highly rigid structure. The headstock has flange construction including precision, hand-scraped mounting surfaces. This minimizes the effects of thermal deformation and vibration, ensuring stable, accurate cutting.
This machine’s ergonomic design includes easy access to the chuck and a front-skirt operation panel, providing convenience for up-close jobs.
Key Specs of the V760EX Vertical Lathe
| Max Turning Diameter | mm (in) | Ø 760 (Ø ) |
| Spindle Nose Type | JIS A2-11 | |
| Speed Range | min⁻¹ | 20~2,000 |
| Power 30 min | kW (hp) | 30 (40) |
| Power cont. | kW (hp) | 22 (30) |
| Rapid Traverse (X/Z) | m/min (ipm) | 24/24 (945/945) |
For more information on Okuma’s V760EX visit http://www.okuma.com/v760ex.
