Pelican Unveils The Versatile 2365 and 2360 LED Flashlights
The 2365 Flex-Neck LED features a nearly 15 inch, flexible cable neck so it that can be bent to shine light anywhere it’s needed. Powered by 2 AA batteries, the 2365’s next generation LED provides clean, brilliant light for nearly 15 hours with a peak output of 45 lumens. Weighing in at 9.3 ounces with batteries, the light comes with a magnetic bracket clip to keep it in place when working around metal surfaces and an MSRP of $49.95.
With a peak light output of 100 lumens, the 2360 LED is powered by 2 AA batteries and boasts a run time up to 2.5 hours. The light also features a multi-position, removable black-oxide coated metal clip. For easy one-handed use the 2360 LED features a tail cap switch and weighs in at a mere 4.6 ounces with batteries. The 2360 LED has an MSRP of $44.95.
Perfect for general use in almost any setting, both lights are weather/corrosion resistant feature CNC Machined Aluminum bodies with a knurled “no-slip” grip pattern and an extremely tough, black Type II Anodized finish. Like all Pelican products, both lights are backed by a Legendary Lifetime Guarantee: “You Break It, We Replace It…Forever”.
http://www.pelican.com
