Research and Markets: Practical Lubrication for Industrial Industries, 2nd Edition
Now completely revised and updated, this book provides those who select and apply lubricants with a comprehensive resource on what products are available, and which lubricants are most effective for specific applications. This new edition expands on the issues of lubricant applications by oil rings (slinger rings) and the elusive problems that often result, and adds a major segment on bearing protector products. The full spectrum of industrial lubricants are addressed, including general purpose oils, hydraulic fluids, food-grade and environmentally friendly lubricants, synthetic lubricants, greases, pastes, waxes and tribosystems. Also examined are lubrication strategies for electric motor bearings, gears, compressors, gas engines and turbines, along with proper lubricant handling and storage, and effective oil analysis.
Key Topics Covered:
  • 1 Principles of Lubrication
  • 2 Lubricant Categories
  • 3 Lubricant Testing
  • 4 General Purpose R&O Oils
  • 5 Hydraulic Fluids
  • 6 Food Grade & Environmentally Friendly Lubricants
  • 7 Synthetic Lubricants
  • 8 Lubricants for Forest Products & Paper Machines
  • 9 Lubricating Greases
  • 10 Pastes, Waxes & Tribosystems
  • 11 Constant Level, Centralized & Oil Mist Lubrication Systems
  • 12 Bearings & Other Machine Elements
  • 13 Lubrication Strategies for Electric Motor Bearings
  • 14 Gear Lubrication
  • 15 Compressors & Gas Engines
  • 16 Steam & Gas Turbines
  • 17 Lube Oil Contamination & On-Stream Oil Purification
  • 18 Storage Methods & Lubricant Handling
  • 19 Successful Oil Analysis Practices in the Industrial Plant
  • Appendix A Lubrication Program Work Process Manual
  • Appendix B Tables, Charts & Factors
  • Glossary of Terms
  • Index
For more information visit http://www.researchandmarkets.com/research/eb3206/practical_lubricat
Contacts
Laura Wood, Senior Manager,
press@researchandmarkets.com
U.S. Fax: 646-607-1907
Fax (outside U.S.): +353-1-481-1716
