ROTALIGN ULTRA LIVE TREND Real-time measurement of machine positional change
ROTALIGN ULTRA LIVE TREND, a short term continuous monitoring application, helps to accurately determine the relative positional changes between coupled machines during run-up or shut-down. It utilizes the unique ROTALIGN 5-axis sensor to monitor continuously, in real-time and simultaneously both the vertical and horizontal parallel and angular displacement of rotating machinery, from cold to hot condition or vice versa. By applying these measured values, the machines can be precisely aligned to reflect normal operating conditions.
This means:
- Lower energy costs through reduced power consumption
- Increased mechanical life of bearings, seals, shafts and couplings
- Reduced bearing and coupling temperatures
- Avoiding breaking or cracking of shafts
- Reduced vibration
- Increase of MTBR (Meantime between failures)
Reliability starts with precision shaft alignment!
For more information, go to: http://www.ludeca.com/prod_rotalignultra-machine-positional-change.php
About LUDECA
LUDECA is a vendor of Preventive, Predictive and Corrective Maintenance Solutions including machinery laser alignment, vibration analysis and balancing equipment as well as software, rentals, services and training. For more information, visit www.ludeca.com
Editorial Contact:
Ana Maria Delgado
AnaMaria.Delgado@ludeca.com
Technical Contact:
Pedro Casanova
Pedro.Casanova@ludeca.com
LUDECA, INC.
1425 NW 88th Avenue
Doral, FL 33172
305-591-8935
www.ludeca.com
