Safer Measurement Capability for Electricians and HVAC Technicians
EVERETT, WA—Fluke Corporation, the global leader in handheld electronic test and measurement technology, has combined three key test tools in an ultra-handy kit for professionals in the electrical and heating, ventilation and air conditioning (HVAC) fields.
The Electrical/HVAC Combo Kit includes the Fluke 62 Mini Infrared Thermometer, the Fluke T+PRO Voltage and Continuity Tester and the Fluke 1AC-II VoltAlert(TM) Non-Contact Voltage Detector, all in a soft carrying case. All three tools are compliant with the 2009 edition of NFPA 70E, and are designed to enable HVAC and electrical professionals to make measurements on live circuits more safely than traditional solenoid testers and contact thermometers.
Together these three tools deliver must-have capabilities for professionals who install, troubleshoot, and maintain electrical and HVAC systems. They can quickly find hot spots and other temperature anomalies, perform multiple tests on electrical circuits, and determine whether circuits are carrying live voltage.
—The Fluke 62 Mini Infrared Thermometer offers quick and reliable surface temperature readings so technicians can diagnose heating and ventilation problems and monitor the temperature of electrical motors and electrical panels without contact. Rugged enough for industrial environments with its protective rubber “boot,” the Fluke 62 Mini has the best accuracy in its class and measures from -30 degrees to 500 C (-20 to 932 F).
—The Fluke T+PRO Electrical Tester has three signals when it detects ac/dc voltage: light, sound, and vibration. It offers the added functionality of a GFCI trip and continuity beeper, plus the convenience of a built-in flashlight. The T+PRO has a rotary field indicator for troubleshooting three-phase systems, measures resistance to 9.99 KOhms, and has a backlit LCD display for easier viewing. Safer than traditional solenoid testers, it is rated for CAT IV 600 V, CAT III 1000 V circuits and fully complies with NFPA 70E.
—The pocket sized Fluke 1AC-II VoltAlert Non-Contact Voltage Detector enables electricians, maintenance and service workers, safety personnel and homeowners to quickly test for energized circuits. Just touch the tip to a terminal strip, outlet, or supply cord. If the tip glows red and the unit beeps, there’s voltage present. It’s rated CAT IV 1000 V and is appropriate for use in most commercial and industrial settings.
The Electrical/HVAC Combo Kit is available from Fluke distributors at a suggested retail price of $189.00, a savings of more than $25 off the cost of the products purchased separately.
Fluke Corporation
For more information on the Fluke Electrical/HVAC Combo Kit, or to find the location of the nearest distributor, contact Fluke Corporation, P.O. Box 9090, Everett, WA USA 98206, call (800) 44-FLUKE (800-443-5853), fax (425) 446-5116 or visit the Fluke Web site at http://www.fluke.com
